Can Wallpaper Engine run on Linux?
I’ve been using Wallpaper Engine for a while on Windows and love it. Recently switched to Linux and I’m wondering if there’s a way to run Wallpaper Engine there. Is it possible to get it working, perhaps through Wine or any other method? Any help would be appreciated, especially detailed steps or alternative solutions.
Certainly, you can run Wallpaper Engine on Linux, but it might require a bit of legwork. Here’s a breakdown for you:
First, you’ll need to use Wine or Proton, Valve’s compatibility layer. Steam’s Proton is often the preferred choice due to its built-in support for many games and applications.
Step-by-Step Guide Using Proton:
  1. Install Steam on Linux: Most Linux distributions have Steam available in their software repositories. For example, on Ubuntu or Debian-based systems, you can install it via the terminal:
    sudo apt update
    sudo apt install steam
    Alternatively, you can download the Steam installer from the official website.
  2. Enable Steam Play: Once you have Steam installed and running:
    • Go to SteamSettingsSteam Play.
    • Check the box “Enable Steam Play for all other titles.” This utilizes Proton for non-Steam games or applications.
  3. Install Wallpaper Engine:
    • Search for Wallpaper Engine in the Steam store and install it as you would on Windows.
  4. Running Wallpaper Engine with Proton:
    • Right-click on Wallpaper Engine in your Steam library.
    • Select Properties.
    • Under the Compatibility tab, check “Force the use of a specific Steam Play compatibility tool” and select the latest available version of Proton from the dropdown menu.
  5. Configuration After Installation:
    • Initially, you might need to configure Wine/Proton settings. Some users report that setting faudio can help. This might involve using a tool like WineTricks or manually adjusting Wine’s configuration.
    • You might also need to deal with some graphical issues. Ensuring your graphics drivers are up-to-date can be crucial. AMD and NVIDIA proprietary drivers usually offer better support for gaming and graphic-intensive applications compared to the open-source alternatives.
Alternative with Wine: If you prefer to use Wine directly:
  1. Install Wine:
    • Again, on Ubuntu or Debian-based systems, you can usually get Wine via:
      sudo dpkg --add-architecture i386
      sudo apt update
      sudo apt install wine64 wine32
  2. Install Winetricks:
    • Winetricks helps manage your Wine installation. Install it using:
      sudo apt install winetricks
  3. Configure Wine for DirectX:
    • Run winetricks, select Select the default wineprefix, then Install a Windows DLL or component, and choose necessary DLLs like dxvk, d3dx9, d3dx11.
  4. Download and Install Wallpaper Engine:
    • Download the installation file from Steam or another trusted source.
    • Use Wine to run the .exe installer:
      wine wallpaper_engine_installer.exe
  5. Running Wallpaper Engine:
    • If you’re using a desktop environment like GNOME or KDE, create a launcher that runs Wallpaper Engine via Wine.
  6. Troubleshoot:
    • Some users have reported issues with certain types of wallpapers. Avoid 3D-intensive wallpapers if you experience performance issues.
Important Notes:
  • Performance: Running applications through compatibility layers like Wine or Proton can result in performance degradation. Always keep your system updated and use the newest versions of Proton or Wine for the best compatibility.
  • File Permissions: Linux file systems are quite different from Windows’ NTFS. Ensure Wallpaper Engine has the necessary permissions to access your user directories.
  • Community Support: Forums like Reddit (r/linux_gaming) and WineHQ AppDB can be incredibly helpful. Keep an eye on user experiences and detailed configurations shared there.
There’s a learning curve with adapting a traditionally Windows-centric application to run on Linux, but numerous users have reported success with the methods I’ve mentioned. Also, always back up your critical data before diving deep into configuration changes.
Hope this helps, and good luck!
Honestly, while using Proton or Wine to run Wallpaper Engine on Linux is a solid approach, let’s consider a different angle.
Why not explore native Linux alternatives?
A few tools are out there, like Komorebi or Variety. They might not have all the snazzy features of Wallpaper Engine, but they can still offer some pretty slick customization right out of the box.
Komorebi allows you to set animated wallpapers, and it’s quite straightforward to use. Here’s a brief rundown:
  1. Install Komorebi: For Ubuntu/Debian:
    sudo add-apt-repository ppa:seleah/ppa
    sudo apt-get update
    sudo apt-get install komorebi
  2. Launch and Customize: Open it from your application menu and start applying wallpapers.
Variety, on the other hand, is more about rotating wallpapers with multiple source options, including online repositories. Here’s how to set it up:
  1. Install Variety:
    sudo apt install variety
  2. Configure: Run the application and set your preferences for sources and rotation frequency.
Now, I get that these might not fully replace the dynamic wallpapers and interactive experiences from Wallpaper Engine, but it’s always good to give native options a try first. They are often better optimized for Linux and can lead to fewer headaches down the road with compatibility issues.
One more thing: Wine and Proton work, but they can introduce random issues or slowdowns that native apps won’t. Plus, considering file permissions and system security—it’s sometimes a hassle that you might want to avoid.
Bottom line: Give Komorebi or Variety a shot. If your heart’s still set on Wallpaper Engine after that and you’re cool with tinkering, then definitely go the Proton/Wine route as previously detailed. Good luck!
Ugh, seriously guys? Jumping through all these hoops just to use Wallpaper Engine on Linux seems like overkill. Let’s be real—Proton and Wine are far from perfect. There’s often performance hits and random crashes. Updates can randomly break stuff too. You wanna go through that every time Steam updates Proton?
Why waste time tweaking when there are alternatives like ‘Variety’ or ‘Komorebi’ right there? Sure, they might not be as flashy but they’re built for Linux, so fewer headaches. You won’t constantly be debugging, and your system won’t turn into a Frankenstein of compatibility layers.
Plus, how many of those dynamic wallpapers are you really using, anyway? For basic wallpaper rotation and minor effects, native tools will save you a TON of hassle. If you’re dead set on dynamic wallpapers, accept the trade-offs; your call, but don’t expect a seamless experience.
Skip Proton. Do this instead.
Use mpvpaper on Wayland or xwinwrap on X11. Play a looped WebM or MP4 as wallpaper. Low overhead, no weird layers.
Steps:
  1. Install mpv and mpvpaper or xwinwrap from your repo.
  2. Grab a short 1080p WebM loop.
  3. Wayland, run: mpvpaper -o ‘no-audio,loop’ HDMI-1 ~/loops/wall.webm
  4. X11, run: xwinwrap -ni -fs -b -nf -un -ov – mpv --loop=inf --mute --no-config --wid WID ~/loops/wall.webm
mpv uses GPU decode, CPU stays low. Works on multi-monitor with per-output runs. Add to your DE autostart. Few tweeks, stable results.
