I’m trying to understand whether AI-powered computer vision can really improve retail detection, inventory tracking, and loss prevention. I recently came across True Detection on LinkedIn, but I’m having trouble figuring out what benefits are realistic and what features actually matter for retail stores. I need help comparing the practical use cases, accuracy, and value for retailers before moving forward.
Yes, AI vision helps in retail, but only if you tie it to a specific store problem.
For inventory tracking, cameras watch shelf gaps, facings, and item counts. Teams use this to flag out of stocks faster than manual walks. Some grocers report shelf accuracy gains in the 10 to 30 percent range after rollout. The catch is camera placement and model training. Bad angles ruin results.
For loss prevention, vision works best on clear events. Sweethearting at self checkout. Item skip. Refund abuse. Door exit mismatch. It struggles more with messy edge cases, so you still need human review. If a vendor claims near perfect detection, I’d be skeptical tbh.
For operations, the best ROI usually comes from labor savings plus fewer stockouts, not theft alone.
If you’re looking at True Detection, check four things.
- What events they detect today, not on a roadmap.
- Their false positive rate.
- POS and VMS integrations.
- How they handle privacy, retention, and audits.
Ask for a pilot in 2 or 3 stores. Measure shrink, out of stock rate, and staff time before and after. If they wont do that, I’d pass.
It can, but I’d separate the hype from the actual retail math.
@espritlibre is right to focus on real store problems, but I’d push one step further: the biggest value is often not “detection” by itself. It’s decision speed. Computer vision is useful when it turns video into something a store manager can act on in the same shift, not three days later in a dashboard nobody opens.
A few places where it actually matters:
- planogram compliance, not just item counting
- promo execution checks
- queue buildup detection
- unsafe behavior in aisles or back rooms
- self-checkout exception ranking so AP teams stop chasing noise
On inventory, people assume vision means perfect real-time stock truth. Usually nope. It’s better at spotting patterns and exceptions than maintaining a flawless perpetual count. If True Detection is pitching “full autonomous inventory,” I’d ask how it handles occlusion, seasonal resets, packaging changes, and lookalike SKUs. That stuff gets messy fast.
On loss prevention, I slightly disagree with the common sales pitch that theft is the main ROI bucket. For many retailers, shrink reduction is too hard to attribute cleanly unless you already have tight controls. Ops compliance and front-end productivity can be easier wins to prove.
What I’d want from True Detection specifically:
- proof by store format, not generic demos
- time-to-alert in real conditions
- who reviews exceptions
- retraining process when store layouts change
- whether alerts fit into existing workflows or just create more work
If the output is “another screen to watch,” pass. If it removes manual checking, then yeah, it can be legit. Just dont buy the sci-fi version of it.
Short version: yes, but only in narrow, measurable use cases.
I agree with @espritlibre on avoiding hype, but I’d disagree a bit on inventory. Vision is not just exception spotting anymore. In tightly controlled zones like receiving, back-room cage areas, and self-checkout, it can be very accurate if camera angles and SKU variety are manageable. The mistake is trying to scale that same promise to the whole store floor.
What I’d evaluate with True Detection:
- camera dependency and install cost
- false positive rate by store condition
- integration with POS, WMS, and case management
- whether it works in bad lighting, crowded shelves, and resets
- how quickly teams can tune rules without vendor hand-holding
Pros for True Detection:
- can reduce manual audits
- useful for self-checkout monitoring
- can surface repeat operational issues fast
- accuracy drops in messy real-world environments
- training and upkeep are often underestimated
- alert fatigue can kill adoption
Best test: one category, one store format, one KPI. If that moves, expand.
