I recently bought an Anki remote to help with my studies, but I’m having trouble getting it to connect to my Mac. I’ve tried looking up instructions online but haven’t found anything helpful. Can anyone guide me through the steps or offer advice? Thanks!
Hey there, I get it, tech can be pretty frustrating sometimes. Had a similar issue myself. Here’s a step-by-step on how I managed to connect my Anki remote to my Mac.
Ensure Bluetooth is on: Simple, but vital. Sometimes we skip the basics. Make sure Bluetooth is toggled on from System Preferences → Bluetooth.
Charge your Anki remote: Yep, make sure it’s charged. Mine had issues because I didn’t realize it was low on battery straight out of the box.
Reset the remote: This isn’t in the manual, but if you hold down the main button for about 10 seconds until it flashes, it sometimes helps.
Mac Bluetooth settings: Head back to Bluetooth settings on your Mac. Your Anki remote should pop up in the list of devices. If it doesn’t, try turning Bluetooth off and back on again.
Pair the remote: When your remote shows up, click Connect. It might ask for a pairing code – I didn’t have to use one, but if it asks, try 0000 or 1234.
Test it out: Open a basic text document and try pressing the buttons. If it’s still not working, you might need to update your Bluetooth drivers. Macs usually handle this automatically, but sometimes manual updates help.
Also, for the sake of thoroughness, check online for any firmware updates for your Anki remote. Sometimes the manufacturer might have a newer version that fixes connectivity issues.
Lastly, if all else fails, a good ol’ restart of your Mac can work wonders. It’s like magic, honestly. Reboot and try the steps again.
Hope this helps! Let us know if still doesn’t work, someone might have a trick up their sleeve here.
For sure, codecrafter nailed quite a few key points there, props for the detailed breakdown! Just to throw in my two cents, here’s a bit of an additional guide to cover any gaps and get that remote up and running:
Check Compatibility: This is a bit of a hit or miss, but sometimes specific models of peripherals, like the Anki remote, can be quirky with certain macOS versions. Double-check on the Anki or Apple forums to see if others have had compatibility issues with the same macOS version you’re running.
Check System Preferences - Security & Privacy:
- Accessibility Settings: The remote might interact with your system at a deeper level requiring certain permissions. Go into System Preferences → Security & Privacy → Privacy → Accessibility and ensure any Anki software or relevant control utilities are allowed.
- Automation Settings: It doesn’t hurt to make sure it’s ticked in System Preferences → Security & Privacy → Privacy → Automation. Sometimes devices need these permissions to work correctly with specific applications.
Third-party App Conflicts:
If you have third-party apps that manage Bluetooth devices, they might interfere with the connection. Consider disabling or uninstalling these apps temporarily to see if that clears up the problem.
PRAM/NVRAM and SMC Reset:
- Reset PRAM/NVRAM: Sometimes your Mac needs a reset of its parameter memory, which holds various system settings. Restart your Mac and hold down Option + Command + P + R for about 20 seconds. This resets your PRAM/NVRAM which might help.
- SMC Reset: System Management Controller reset could also help. Shut down your Mac, and for laptops with non-removable batteries, press Shift + Control + Option on the left side of the keyboard and the power button at the same time for 10 seconds, then release them, and turn the Mac back on.
Hardware Test:
Run a hardware diagnostic to make sure Bluetooth hardware isn’t malfunctioning. Restart your Mac, press and hold “D” key to enter diagnostics mode, and follow on-screen instructions.
Unpair all Bluetooth devices: Your Mac’s Bluetooth stack might be clogged up. In the Bluetooth preferences, temporarily remove all other paired devices. Restart your Mac then try to pair the Anki remote again before re-pairing any other devices.
Terminal Commands: For those who are comfortable with Terminal:
- Reset Bluetooth module:
sudo pkill bluetoothd - Clear Bluetooth plist files:
sudo rm -R /Library/Preferences/com.apple.Bluetooth.plist sudo rm -R ~/Library/Preferences/com.apple.Bluetooth.plist sudo shutdown -r now
Note: Use Terminal commands carefully, as they involve managing system files and require administrative rights.
Router/Interference Issues: Sometimes, especially in crowded signal areas, your Wi-Fi router or other wireless devices can interfere with Bluetooth signals.
- Move closer to the Mac to ensure a stronger signal.
- Disconnect or move away other wireless devices/mobile devices to reduce interference.
Perform a Bluetooth hardware reset by:
- Boot into Safe Mode: Restart your Mac holding Shift right after the chime, let it run a diagnostic in Safe Mode, and then reboot normally.
- Or, use a USB Bluetooth dongle if your internal Bluetooth is truly on the fritz. Several third-party dongles add Bluetooth without messing with the internal hardware.
Firmware and Software update:
Codecrafter mentioned checking for updates, definitely crucial. Besides the Anki firmware, software updates can often include essential fixes. Don’t just rely on automatic updates; manually check for updates in both Anki software and macOS periodically to avoid missing any critical patches or updates.
Finally, community forums:
Don’t forget the power of community! Check with user forums like MacRumors, Apple Support Community, and even Reddit for quirks and tips from other Anki remote users.
Hope these extra steps give that final push to get things working. Tech is a mixed bag, so persistence usually pays off.
That’s a lot of steps for something that should be straightforward. It sounds like the Anki remote might be more trouble than it’s worth. Have you considered just using a different Bluetooth device, like a Logitech remote or even a basic Bluetooth keyboard? They’re generally more user-friendly and less prone to weird compatibility issues.
Honestly, resetting PRAM/NVRAM and SMC for a simple remote connection seems overkill. If the Anki remote’s not connecting after basic troubleshooting, it might be poorly designed for Mac systems, or you could have a defective unit.
If none of these solutions work, it might be time to return the Anki remote and get a different brand. Sometimes it’s just not worth the hassle to try making incompatible tech work. And, not to be a downer but, all these steps feel like a temporary fix rather than a long-term solution. Save yourself the headache and go for something more reliable.
Skip the remote. Turn your phone into the Anki controller. Install Remote Mouse or Unified Remote on Mac and phone. Connect over WiFi or Bluetooth. Map buttons to Anki keys, Space shows answer, 1 to 4 rate, R redo, E edit. Open Anki, start the server app, then tap your custom buttons. Setup takes 3 to 5 mins. If youre offline, switch the app to Bluetooth mode. This avoids flaky pairing. Works on macOS 13 and 14.
