How do I use OneDrive Personal and Business on the same computer?
I’m trying to set up both my personal and business OneDrive accounts on my Windows PC, but I’m running into issues syncing or accessing both at once. Has anyone successfully managed to do this, and can you share the steps or any solutions? I need to keep both accounts easily accessible for work and personal files.
How Do You Juggle Personal and Work OneDrive in CloudMounter? Here’s What Actually Worked for Me
Okay, I’ve been down the rabbit hole trying every trick and tip Google could cough up about connecting both my own private OneDrive and the OneDrive from my job… and nothing clicked until I wrangled CloudMounter into the mix. So, if your desktop is starting to look like a spaghetti bowl of sync folders, buckle up—I promise this route is less rage-inducing than the others.
Why Even Bother? Because Microsoft Won’t Make It Easy
Ever feel like Microsoft made it intentionally convoluted to run two OneDrive accounts, so you’d give up and just stick with one? The built-in tools will only let you add ONE personal account and then ONE business one at a time (and often kick you out for daring to mix the two).
Rolling in with CloudMounter: Step-by-Step
So after trial, error, and way too much caffeine, here’s how this pans out:
1. Fire Up CloudMounter
Find it, install it, run it. Not a massive download—could probably finish while you grab coffee.
2. Add Your Regular OneDrive
In CloudMounter’s interface, just smack that “+” or “Add New Connection,” pick OneDrive. It’ll have you punch in your Microsoft login. Stay chill—it’ll authorize the app and spit out your regular files.
3. Layer on OneDrive for Business
Here’s where the magic happens, and yes, it’s “for business,” but you can use an EDU account too. Go back, repeat the add-new process, but this time choose the “OneDrive for Business” or Microsoft 365 Work. Log in with your work credentials. Presto—you’ve got both sitting side by side in the interface.
4. Managing Them? Just Click Between
Both drives show up like separate cloud storage—no weird merging, no accidental file swaps. You can drag, drop, edit, rename, all without that wobbly juggling act that happens when you try to run two OneDrive apps at once.
No More Logging In or Out (And No Multiverse Collisions)
Tried other routes—browser incognito windows, manual syncing, sketchy third-party scripts—nothing was as stable or as straightforward. CloudMounter’s setup actually lets you live in one window, swapping between your home and work stuff without having to re-authenticate five times. You don’t lose context, and, bonus, you don’t get yelled at by the IT department for messing with official company sync settings.
In a Nutshell
If you’re as tired as I was of Microsoft “limitations,” this method honestly saves you a lot of hair-pulling. Other options are either needlessly complex, constantly log you out, or force you to pick and choose between job and personal files. CloudMounter finally cracked it for me, and now everything just… works.
If you got a better way, I’m all ears, but after slamming into every wall, this is the only thing that stuck.
This is one of those things that feels like it should be simple, but Microsoft just makes it weirdly arcane. I get where @mikeappsreviewer is coming from about using CloudMounter—I’ve tried it, and yeah, it works if you’re okay with a 3rd party utility. But honestly, I’m stubborn and wanted to see if the “official” method could be wrangled instead.
Here’s what actually runs natively: Windows will let you sign in with one personal OneDrive and one OneDrive for Business using the OneDrive sync app. Start with signing into one via the regular OneDrive client (click the cloud icon in your tray, sign in, pick folder, etc). Then, go back to “Settings” > “Account” in OneDrive, and hit “Add Account”—this will let you bring in your business or work (Microsoft 365) account alongside your personal one. Both accounts sync to separate folders (usually “OneDrive – Personal” and “OneDrive – [Business Name]”) in your user directory.
But—and this is a big but—if you try adding a second personal account or multiple business accounts, OneDrive flat refuses. No hacks, no regedit tricks, nothing sticks. Also: It sometimes logs you out, and you still get the occasional “sync error” if something’s weird with your company’s admin settings. Infuriating but technically “supported.”
If your job is super picky about 3rd party tools, you might have to just deal with Microsoft’s wonkiness. That said, CloudMounter definitely sidesteps the sync folder chaos: no double-up folders, no logging in/out, you can browse both clouds hassle-free. I know I said I wanted to avoid external apps, but real talk: If you’re juggling files a lot or need more than 2 cloud accounts, Microsoft’s out-of-the-box support is half-baked at best, borderline useless at worst. CloudMounter makes the mess tolerable. (And no, SharePoint or web-only access isn’t a real solution unless you like suffering.)
TL;DR: You can use a personal and business OneDrive on Windows, but only one of each, and it’s…clunky. For true sanity, CloudMounter’s probably worth it (don’t tell my IT guy I said that). Anyone else found a native method that supports more than those basic combos? Or do we all just end up using 3rd party stuff anyway?
Okay, hot take—Microsoft’s idea of “supporting multiple accounts” on OneDrive is honestly like trying to play Jenga on a rollercoaster. Both @mikeappsreviewer and @viajantedoceu bring up CloudMounter (no argument, it’s slick if you’re done fighting with the stock solution) and the native sync app sort of supports a dual-lane action, but honestly, neither route ever felt bulletproof for me.
Here’s my half-rant, half-experience: you can add one personal and one business account to the OneDrive app, but the minute you want more flexibility (like a second personal, multiple work creds, or to not have all your stuff slamt into local folders), things get crunchy. The official app logs out, freaks out, or gets stuck in “Processing changes…” for, like, eternities if your org has certain policies. And don’t get me started on file version conflicts—oh, the number of “copy of copy of’ files I’ve cleaned up.
I actually ended up just using the Windows app for my work files (because IT audits are a thing), and then for personal stuff, I ONLY use the browser (incognito for less cookie drama). Not seamless, but at least less of a syncing warzone. When things got really hairy—like I had personal, freelance, AND day job accounts? That’s when I caved to using CloudMounter. Drag, drop, don’t care, no folder bloat, and the UI is like “Yep, got your clouds right here.” Didn’t love trusting a 3rd-party app at first, but honestly? Better than rage-quitting when Microsoft’s own app refuses to play nice.
Side note: Anyone else ever have OneDrive decide to randomly “unsync” certain folders with zero warning? Had to re-download half my stuff once. Not fun.
If you absolutely must stick native, your only route is: add personal first, then business, keep both folders separate, and never try juggling more. Otherwise, CloudMounter is just…less chaos. Seriously starting to feel like Microsoft does this on purpose so we’ll just buy more 365 accounts lol.
TL;DR: Official method—possible, but fragile. CloudMounter—not free, but way less pain. Anyone else survive using just the browser? Or is everyone else also secretly running third-party apps behind IT’s back?
Let’s cut through the folder-salad confusion: juggling OneDrive Personal and Business accounts on Windows is meant to be “easy,” according to Microsoft, but in practice… yeah, not so much. You’re pretty much locked into ONE personal plus ONE business in the native app, and even then, it can get squirrelly if your IT overlords have strict security policies (random sign-outs, absurd sync errors, etc.—IYKYK).
There’s a LOT of talk about using CloudMounter, and, honestly, it’s deserved. For sheer sanity, swapping between OneDrive Personal and Business in CloudMounter is a breeze: no more “processing changes” for eternity or surprise folder disappearances. You get a clean, visual interface showing both drives as separate “locations.” Drag and drop, copy between, and—importantly—NO forced local file duplication (unlike the standard OneDrive sync that chews up disk space with local copies).
Pros of CloudMounter:
  • Handles personal and business OneDrive at the same time—truly side by side.
  • No need to keep logging in/out or living in multiple browser tabs.
  • Doesn’t sync everything to your drive by force; cloud-only storage saves disk space.
  • Generally immune to those random sync-bug outages that plague Microsoft’s native client.
  • Not free—subscription or paid (which, yeah, stings if you’re trying to minimize expenses).
  • You’re relying on a third party for access to potentially sensitive work stuff (depends how trustworthy you feel).
  • Certain advanced sharing or file settings sometimes require the native client or browser (e.g., sharing links with org policies).
Other options? Some folks like @viajantedoceu or @codecrafter stick to browser windows (incognito if you’re fighting cookies), while others keep one in the app and the other in-browser only—limiting but workable.
One alternate “hack”: Use Windows’ built-in “Add a new user” feature, then log into a second OneDrive in a second Windows profile and use “Fast User Switching.” Total overkill for day-to-day, but handy for power users who REALLY need both synced natively (including right-click explorer access).
Final take: For most, CloudMounter is just less frustrating than the official sync tool’s limitations. It’s not perfect, but it does what Microsoft should have done natively. If you’re allergic to subscriptions, the browser-only route is probably safest, but for those who hate folder chaos? CloudMounter is as zen as it gets.
Use the native OneDrive sync app for your work account only.
Handle your personal OneDrive through a dedicated browser profile.
  1. In Edge or Chrome, create a profile named “Personal”.
  2. Sign in there to your Microsoft personal account. Pin onedrive.live.com.
  3. Keep your work OneDrive in File Explorer via the sync client.
  4. When you need personal files, open the Personal browser. Download or upload as needed.
This keeps accounts separate, avoids sync conflicts, and needs no extra software.
