Need help canceling an Amazon order before it ships
I accidentally placed an Amazon order with the wrong item and shipping address, and it’s already showing as processing. I’m confused about where to click and what options to choose so I don’t get charged or have it delivered. Can someone walk me through the exact steps to cancel an Amazon order and what to do if it’s already shipped?
Had to deal with this last week, here is the simple version so you do not get stuck.
  1. Go to Your Orders
    • On desktop, click Returns & Orders at the top right.
    • On the app, tap the person icon, then Your Orders.
  2. Find the order
    • Look for the wrong item.
    • Check the status text under it.
    • If it says “Processing,” “Preparing for shipment,” or “Not yet shipped,” you still have a shot.
    • If it says “Shipped” or shows a tracking number, you are too late to cancel through the normal button.
  3. Try to cancel
    • Click or tap “Cancel items” or “Request cancellation.”
    • If you do not see that, click “Order details” and look again.
    • Select the wrong item.
    • Pick a reason like “Ordered by mistake” or “Wrong address.”
    • Confirm the cancel request.
  4. Check for confirmation
    • Amazon sends an email if the cancel goes through.
    • The order in Your Orders should show “Canceled.”
    • If it says “Cancellation pending,” the seller has to approve.
  5. If it already shipped
    • You cannot stop the charge now. They charge when it ships.
    • Wait for the package.
    • Once delivered, go to Your Orders.
    • Click “Return or replace items.”
    • Pick “Bought by mistake” or “Wrong item ordered.”
    • Follow the steps to get a return label.
    • Drop it at the listed location. Refund hits after they receive or scan it, often 3 to 7 days.
  6. Wrong address fix
    • For Amazon shipped orders, sometimes you see “Change delivery instructions” under the order. That helps a bit, but not for the full address in most cases.
    • If the driver has the package, use “Track package” and look for “Contact driver” or “Delivery instructions.”
    • If it is going to a bad address and you cannot fix it, let it fail delivery. It often goes back and you get a refund.
  7. If it is a third-party seller
    • If cancel button is gone, click “Problem with order” or “Contact seller.”
    • Send a short message:
    “Hi, I ordered by mistake with wrong address. Please cancel before shipping if possible.”
    • Some sellers ignore it, some respond in a few hours.
  8. Money part
    • If cancellation works before shipping, the charge drops or never finalizes.
    • If you already see a pending charge, your bank will release it in a couple days after cancel.
    • For returns, refund hits the original payment method.
If your order is time-sensitive or pricey, use chat or phone:
Account & Lists > Help > Something else > Chat with us or Request a call.
Tell support “Wrong item and wrong address, need cancel before ship.” They move faster than the seller in many cases.
If it’s already “processing,” you’re basically racing the warehouse clock, so here’s what I’d do that’s slightly different from what @boswandelaar laid out:
  1. Skip the menus, go straight to Help
    On desktop:
    • Hover “Account & Lists”
    • Click “Help”
    • At the bottom: “Need more help?” → “Contact us”
    In the app:
    • Three lines (☰) → Help & Support → “Chat with us”
    Don’t waste time clicking around Your Orders if the Cancel button is missing or grayed out. Every minute counts once it says “processing.”
  2. Use very specific wording in chat
    Type something like:
    “I placed the wrong item with the wrong address. Order is currently ‘processing / not yet shipped’. I want the entire order canceled so it is NOT delivered and I am NOT charged. Please confirm cancellation.”
    Key part is: “entire order” and “not be charged.” They sometimes try to “update” the address instead of canceling, which is useless if the item is wrong anyway.
  3. Push for instant confirmation
    • Ask them to confirm in chat that the order shows as “Canceled” on their side.
    • While you’re still in the chat, refresh Your Orders in another tab and see what it says.
    • If it says “Cancellation requested” or “Pending,” ask support:
      “Can you override and force cancel on your side? I don’t want it to ship at all.”
    Sometimes support can nuke it even when the normal Cancel button is gone. This is where I lightly disagree with @boswandelaar: “Shipped” on your screen isn’t always the final truth. Support can occasionally intercept if it’s only generated a label but not physically left.
  4. If it’s a third party seller and support shrugs
    • Ask support to message the seller and refund if the package comes back undeliverable.
    • Also toggle “Problem with order” in Your Orders and select something like “Need to cancel order.”
    • You want a written trail in both places so if the seller drags their feet, Amazon sides with you.
  5. Wrong address trick that sometimes works
    If it’s fulfilled by Amazon and already too far to cancel:
    • Go to “Track package.”
    • If you see “Update delivery instructions,” put something like “Ring, do not leave with anyone else, call this number.”
      This does not fix the actual address, but it can slow things or cause a delivery fail if the driver cannot match the instructions. Failed delivery usually auto-refunds once it returns to the warehouse.
  6. Watch your payment method
    • If the cancel works: any pending auth charge should disappear in 1 to 3 business days.
    • If it ships anyway: let it deliver, then immediately open a return with reason “Ordered wrong item / wrong address” and pick the cheapest dropoff method. Keep the return receipt or scan proof; that speeds up any refund argument.
tl;dr: with “processing,” skip hunting for buttons and hit Help → chat/call, be very explicit that you want the whole thing canceled and not charged, and double check Your Orders while you’re still talking to them so you don’t get stuck in limbo.
Short version: you have two battles here, time and status. What @sternenwanderer and @boswandelaar covered is the “button path.” Let me add the “what to watch out for” side so you do not assume it is fixed when it is not.
  1. Do not rely only on the cancel email
    This is where I slightly disagree with both. The email can lag. I have had “Your order is canceled” in my inbox while the order still showed as preparing for shipment and then shipped anyway.
    • After you request cancellation or talk to support, keep checking Your Orders every 10–15 minutes for the next hour.
    • You want to see the order move to the Canceled section, not just “Cancellation requested.”
  2. Watch the status wording like a hawk
    The exact phrase matters more than the generic “processing”:
    • “Not yet shipped” / “Preparing for shipment” → best chance to kill it.
    • “Shipping soon” → that usually means the box is already labeled. Customer service might still be able to pull it, but assume odds are low.
    • “Out for delivery” → at this point it is basically a future return.
  3. If your main worry is the wrong address
    Both earlier replies focus on canceling. In practice, Amazon often prefers to deliver and then refund. For a bad address, that can actually work in your favor:
    • If it is a fake or unreachable address, do nothing and let it fail delivery. It will get returned and auto refunded in many cases.
    • If it is a real address where a stranger might accept the parcel, use Track package and hammer every “delivery instruction” option to make it harder to hand to the wrong person. Think “Call this number first” or “Do not leave with neighbor.”
  4. Third party seller reality check
    I would be a bit more pessimistic than @sternenwanderer here. When it is a marketplace seller, “Cancellation requested” often just means “we sent them a note and now we all hope.”
    • If it is something expensive, open a parallel A-to-z Guarantee claim as soon as they ship but before it is delivered. Your claim reason: ordered by mistake, tried to cancel before shipment, seller sent it anyway. That paper trail helps if the seller drags out refunds.
    • Keep screenshots of timestamps: when you requested cancellation vs when tracking was created.
  5. About “you will not be charged”
    Very important nuance:
    • Many banks will still show a pending authorization even if Amazon cancels quickly. That is your bank holding funds, not Amazon recharging you.
    • If the order is canceled, Amazon will not settle it, so the hold should vanish within a few business days. Do not re-cancel or re-order the same item five times because you think each hold is a new charge.
  6. If support offers to “change the address”
    Here I diverge a bit from both competitors. If the item is wrong, do not accept an address change instead of a full cancel. That only guarantees the wrong thing arrives correctly.
    • Phrase it clearly: “The item and address are both wrong. I do not want this shipment under any address. Please cancel the order entirely.”
  7. Mental model to avoid future pain
    Think of Amazon orders like this:
    • Phase 1: Editable (you can cancel or change almost anything).
    • Phase 2: In the conveyor belt (the site lies a little, support sometimes has special nukes, but odds drop).
    • Phase 3: On a truck (you are in return/refund territory, not cancellation).
      The confusion often comes from expecting Phase 1 powers in Phase 2 or 3.
Bottom line:
Use the cancel / request cancellation paths that @boswandelaar detailed, sprint to chat/phone like @sternenwanderer suggested, but do not relax until (a) the order is in the Canceled section, or (b) tracking shows it coming back and your refund is logged under that order.
