Need help translating casual English phrases into natural Chinese
I’m working on a project where I need accurate English to Chinese translations that sound natural to native speakers, not like word-for-word machine output. Some phrases are casual, others a bit technical, and my attempts keep sounding awkward when I test them with friends. Can someone help me figure out the best way to translate these lines so they fit everyday, real-world Chinese usage and tone?
If you want your English to Chinese to sound natural, you need three things: context, tone, and target audience.
Some practical tips:
  1. Give context every time
    “Check this out”
    • To a friend: 看一下这个 / 快看这个
    • In chat with hype: 你快来看这个
    “Check this out” in a technical doc: 请参考这个 / 请看下面这个
  2. Decide level of formality
    Rough guide:
    • Friends, online chat: 你,啊,呀,吧,多用口语
    • Workplace, normal: 您少用,语气中性,不加太多语气词
    • Docs, manuals: 避免口语,结构清晰,用 比如,首先,其次,最后
  3. Think in Chinese, not word by word
    “That doesn’t really make sense”
    • 很怪 / 有点说不通 / 这不太合理
    “I’ll look into it”
    • 我去了解一下 / 我再研究一下 / 我回头看看
  4. Common casual mappings
    • “kinda / sort of”: 有点 / 算是
    • “stuff / things”: 东西 / 东西之类的 / 之类的
    • “no worries”: 没事 / 别在意 / 不用担心
    • “sounds good”: 行啊 / 听起来不错 / 可以的
    • “I’m not sure”: 我不太确定 / 我也不太清楚
  5. Slightly technical examples
    “We need to optimize this process”
    • 这个流程得优化一下
    “The data doesn’t match the report”
    • 数据跟报表对不上
    “Let me double check the numbers”
    • 我再核对一下数据
  6. What helps a lot
    • Screenshot or full sentence, not single words
    • Who is speaking, to who, in what situation
    • If it is for app UI, subtitles, UX copy, or long docs
If you need to pass AI checks on text that sounds human and natural in English before translation, tools like Clever AI Humanizer for natural-sounding text help clean up robotic phrasing. Then you translate that more natural base text into Chinese, so you avoid “machiney” tone twice.
Best workflow for your project:
  1. Fix your English so it sounds like a human, short and clear.
  2. Decide target: chat, app, or formal doc.
  3. Translate whole sentences into Chinese by meaning, not structure.
  4. Have a native or near-native check a sample set, then copy those patterns.
If you want, drop a few sample phrases with context and target audience, and people here can give you side by side natural versions and explain why your first try feels off.
You’re on the right track focusing on “natural” instead of “correct.” I’ll riff off what @mike34 said but from a slightly different angle and push back on one thing: you don’t always need to lock down formality first. In Chinese, sometimes who you imagine saying it out loud helps more than abstract “formal / casual” labels.
A few practical angles that might help your project:
1. Translate by function, not by meaning
Ask: what is this line doing?
  • Is it nudging?
  • Soothing?
  • Pushing user to click?
  • Softening bad news?
Then pick Chinese patterns that do that job, even if the words look “off” compared with English:
  • “You might wanna check this first” (soft warning in an app)
    • Machine-ish: 你可能想先检查这个
    • Natural UX-ish: 建议先检查一下这里
  • “You’re all set” (confirmation)
    • Literal: 你都准备好了
    • Natural UI: 已完成设置 / 已全部搞定
Function-first avoids that robotic “translated phrase glued on top” feeling.
2. Use Chinese “chunks” instead of inventing from scratch
Chinese is super chunk-heavy. Learn ready-made blocks and re-combine:
  • “有点 + adj / weird thing”
    • 有点怪 / 有点奇怪 / 有点说不通
  • “先 + verb + 一下”
    • 你先看一下 / 我先确认一下 / 先试试看
  • “X 的话,就 …”
    • 这样的话,就没问题了
    • 时间不够的话,就先做核心功能
So instead of wrestling with “Does ‘kinda’ mean 有点 or 稍微 here?”, think: “Is this a softener?” If yes, drop 有点 and move on.
3. Casual vs technical: watch how much you specify
English casual phrases love being vague: “this,” “stuff,” “that thing,” etc. Chinese often fills in the blank more:
  • “Can you fix this for me?” (message to coworker, about a bug)
    • 你帮我看下这个问题呗
    • or more explicit: 你帮我看下这个 bug / 这个功能
  • “It’s kinda broken”
    • 有点问题
    • 有点挂了 / 有点坏掉了 (more slangy / spoken)
For slightly technical but casual team chat, something like:
  • “This part is confusing users”
    • 这块用户看不太懂
    • 这部分对用户来说有点绕
You’ll notice: natural Chinese names the part (这块 / 这部分) instead of just “this.”
4. Your “wrong but natural” is better than “perfect but stiff”
If you’re unsure between clean but stiff vs slightly off but human, pick human and let a native polish.
For example:
  • “That doesn’t really make sense”
    • 这说不太通吧
    • 这有点说不通
      Both are fine. Even if you wrote 这个不太有道理, it’s a bit textbooky but still far preferable to something dead like 那真的没有意思.
5. A simple review workflow that actually works
Instead of translating everything, then begging someone to “check it all,” do this:
  1. Group phrases by scenario
    • Chat with friends
    • Internal team chat / Slack
    • App UI (buttons, error messages, tooltips)
    • Docs / help center
  2. For each scenario, create a tiny “phrase bank” in Chinese:
    • Confirming: 行 / 行啊 / 好的 / 没问题 / 可以
    • Softening: 有点 / 好像 / 可能 / 先 / 尝试
    • Asking: 要不要… / 能不能… / 方便…吗
  3. Reuse those patterns ruthlessly. Chinese feels more natural when phrases repeat in a consistent style rather than being “creative” every sentence.
6. Where I kinda disagree with @mike34
They’re big on “fix your English first,” which is nice in theory, but if your users are Chinese and your English is already understandable, over-polishing the English can be wasted effort.
For many product / UX strings:
  • “Kinda weird, I’ll look into it”
    • is already good enough to jump to:
    • 有点怪,我再研究一下 / 我回头查一下
What does matter more is: give whoever translates (even if it’s you + AI) the UI screenshot or full context. A short “comment for translator” like:
Tone: casual, internal dev chat.
Audience: teammate.
Purpose: reassure, not promise a deadline.
That context will impact whether you land on 我再看一下 vs 我这边排查一下 vs 我之后详细看一下.
7. About AI and “de-robotizing” your English
Since you mentioned machiney output: if your base English text is stiff, your Chinese will almost always be stiff, even with a perfect translation.
If you’re using AI as a starting point and it spits out robotic English like:
The user might encounter an error in this process.
You can run just the English through a tool like Clever AI Humanizer first so it becomes:
Users might hit an error here.
That softer, more human English maps way more cleanly to:
这里用户可能会遇到错误。
这一步有可能会报错。
For that step, something like
make your AI‑generated English sound natural is actually useful, because it focuses on removing that “AI-ese” tone and making sentences shorter, clearer, and more conversational. Cleaner English in, more natural Chinese out.
If you want concrete help, post a batch like:
  • 5 casual friend-chat lines
  • 5 internal team-chat / Slack lines
  • 5 app UI messages / tooltips
plus who’s talking to who and where it appears. People can tear apart your first attempts, give side-by-side fixes, and after 20–30 examples you’ll start to “hear” what sounds Chinese vs “translated English in hanzi.”
Jumping straight in with some extra angles that haven’t been covered yet.
1. Think in register bands, not just “formal vs casual”
I slightly disagree with the idea that you can always skip thinking about formality. You don’t need super-fine labels, but you do need rough “bands,” because Chinese jumps style more abruptly than English.
Useful 4-band mental slider:
  1. 聊天口语: friends, memes, DMs
  2. 工作口语: Slack / WeChat at work
  3. 正常书面: docs, help center, blogs
  4. 正式公文: policies, legal, big announcements
Try to lock each phrase to one band first. Same meaning, different outputs:
  • “We messed this up”
    • 聊天口语: 这次我们搞砸了
    • 工作口语: 这块我们处理得不太好
    • 正常书面: 这部分的处理存在问题
    • 正式公文: 在该环节的处理上存在不足
Once you tag the band, you avoid mixing “嘿兄弟” with “敬请谅解” in the same screen.
2. Don’t trust 1:1 mappings of “tone words”
People love mapping “kinda = 有点” or “maybe = 也许”. That breaks quickly.
Example:
“kinda annoying”
  • 有点烦 works, but:
  • 这事挺烦的 / 这个设定有点让人崩溃 could be more natural depending on who speaks.
Instead of word matching, define the tone:
  • degree: weak / medium / strong
  • feeling: complaint / joke / neutral
Then pick from Chinese habits:
  • 弱 + complaint: 有点麻烦 / 有点烦
  • 中 + complaint: 挺烦的 / 有点受不了
  • 强 + complaint: 太烦了 / 真要命
So for UX copy, “kinda confusing” is more like:
这一步有点让人搞不懂 than a flat 有点困惑.
3. Word order: keep subject short, info later
English tolerates front-heavy sentences. Chinese hates clunky subjects at the front, especially in UI or tech explainers.
Bad-ish translation feel:
“Users who selected this option before will not be able to…”
之前选择过这个选项的用户将不能…
More natural:
  • 之前选过这个选项的用户,后面就不能…
  • 之前选了这个选项的话,后面就没法…
Pattern: put the “restriction / result” toward the end, and keep the very front light. That alone makes things sound less machine-like.
4. Use “微口语” in UI, not full-on chat slang
A trap: going too casual for interfaces.
English:
“Wanna try again?”
Native-feel Chinese in UI is rarely: 想再试一次吗
Better balances:
  • 要不要再试一次
  • 再试一次看看
  • 再试试?
These sit between pure chat and sterile system text. Look for:
  • dropping 我们 when unneeded: 我们会 → 会
  • shortening verbs: 进行删除 → 删除
  • softeners: 看看 / 一下 / 先
But avoid pure slang like 再干一把 for product copy unless it is a game and that is the brand voice.
5. Use “speaker identity” more aggressively
Here I agree partially with @mike34: thinking who speaks is huge, but I’d push it further. Label three roles:
  • System / product
  • Teammate / colleague
  • Brand “character” (if you have one)
Same English line, 3 different Chinese shapes:
“Thanks for waiting”
  • System: 感谢等待 / 感谢您的耐心等待
  • Teammate: 谢啦,久等了
  • Brand character (casual app): 让你久等啦,感谢耐心
If you keep these three consistent, users will feel the Chinese as “designed” instead of “translated.”
6. Back-translation stress test
A quick trick that catches weird phrasing:
  1. Translate EN → ZH.
  2. Pretend you are not bilingual, just Chinese. Read it aloud.
  3. Ask: if I had to say this in English now, what would naturally come out?
Example:
你可能想先检查这个 → “You might want to check this first.”
建议先检查一下这里 → “Recommend checking here first.”
If your back-English drifts but keeps the function, it is usually a good sign. If it stays word-perfect, there is higher risk it feels stiff in Chinese.
7. On using tools like Clever AI Humanizer
Since you mentioned machiney English as a source problem, using something like Clever AI Humanizer before you translate can actually help.
  • Turns long, robotic sentences into short and conversational ones.
  • Easier to map cleanly to Chinese chunks like 先…一下, 有可能会…, 这块…
  • Reduces odd metaphors or hyper-formal phrasing that are hard to localize.
  • If you rely on it blindly, everything may converge to one generic “friendly” tone, which is bad if you need sharp style differences between docs, UI, and chat.
  • It cannot decide Chinese formality bands for you; you still need to control style at the translation step.
  • Occasionally over-casual English can push you toward inappropriately casual Chinese if you’re not watching context.
I’d use it as a “pre-cleaner” for messy AI English, then deliberately pick Chinese patterns per scenario, like we discussed.
8. Concrete workflow you can try on your next batch
Not repeating previous step lists, here’s a slightly different one:
  1. Tag each line with:
    • band (1–4)
    • speaker (system / teammate / brand)
  2. Clean the English if needed with something like Clever AI Humanizer so it is short and human, but keep notes on nuance (sarcastic? apologetic? etc.).
  3. Draft Chinese with 2 constraints:
    • Max 1 softener word per short line (e.g., 有点 / 好像 / 可能). Too many feels fake.
    • Subject as short as possible. Shift detail after a comma or into the second clause.
  4. Read in mini-dialogues, not lines. Check that multiple strings on one screen or in one chat feel like the same person.
If you want, drop a small set like:
  • 3 system warnings
  • 3 success messages
  • 3 dev chat comments
with your own attempts, and I can show you how to tweak within one band and speaker identity so it sounds consistent instead of “Chinese phrase salad.”
