What's the best way to disable battery saver on an Android phone?
Recently, my Android phone’s battery saver turned on automatically, and now it’s messing with my app notifications and background data. I tried navigating through settings but can’t seem to find the right option. Can anyone guide me on how to switch off the battery saver mode? Thanks!
Alright, here’s a step-by-step guide to disable the battery saver on your Android phone that should help you out. Navigating through settings can be a bit tricky at times, but once you know the exact path, it gets easier.
  1. Open the Settings app: This is usually represented by a gear icon on your home screen or in your app drawer.
  2. Find and tap on ‘Battery’ or ‘Power Management’: Depending on your Android device and its OS version, the wording might slightly differ. Sometimes it’s under the “Device Maintenance” section if you’re using a Samsung.
  3. Battery Saver: Look for an option labeled ‘Battery Saver’, ‘Power Saving Mode’, or something similar. This can often be found within the Battery settings.
  4. Turn off Battery Saver: You should see a toggle button that you can switch off. Sometimes it’s directly visible, other times you need to enter an additional menu labeled something like ‘Battery Saver’ where you can turn it off.
In some Android versions, there might be a Quick Settings tile. You can pull down the notification shade and look for the Battery Saver icon (often a battery with a plus sign). If it’s active, just tap it to deactivate.
However, be careful whenever you toggle off Battery Saver mode, especially if you rely heavily on your battery lasting throughout the day. If your battery life is low frequently, it might be because of background apps or certain settings consuming a lot of power. If you switch off the Battery Saver and still encounter quick battery drainage, you might want to look into optimizing your settings or using apps designed to manage battery life better.
Also, ensure your apps are updated. App developers often release updates that improve battery usage. If everything seems up to date and you still face issues, you might want to check in with your phone’s manufacturer support or community forums specific to your device model.
If you can’t find these options, please mention your phone model and Android version. Sometimes the path varies a bit more on non-stock Android ROMS like those from Samsung or Huawei.
Seriously, so many steps just to turn off Battery Saver? Real talk, there are easier ways. You could’ve simply held down the power button and accessed ‘Battery Saver’ from the quick settings, faster and more direct.
But, if you’re all about going through settings, fine. Here’s something else though: Be cautious. Disabling Battery Saver will drain your battery super fast, especially if you’re one of those people who run a million apps at once.
Another thing people don’t talk about is the alternative battery management apps available on the Play Store. Some do a better job than the built-in stuff and are way more customizable. Look into apps like Greenify or AccuBattery. They’re not perfect (nothing is), but they can help balance performance and battery life.
But really, the best fix might just be to manage your phone use better. Do you really need all those notifications immediately? Maybe just clean up your phone a bit, turn off unnecessary background processes.
A final thing to keep in mind: not all Android skins are the same (Samsung, Huawei, etc.). Sometimes these steps change slightly and can get confusing. Sometimes it’s just buried deeper than it should be. It’s typical Android inconsistency for you.
Hey everyone, just jumping in here with another angle on this battery saver mess!
So, I know @techchizkid and @codecrafter have covered the standard procedures, but I wanna add a bit more flair. Honestly, turning off Battery Saver isn’t rocket science, but some elements can be overlooked!
First off, consider this: your phone’s battery is going bonkers while running lots of apps. Sure, turning off Battery Saver is fine for the immediate fix, but long-term? Nah. Here’s how to handle this slick:
  1. Check App Permissions: Sometimes, apps sneakily keep running in the background, siphoning power without you even knowing. Go into Settings > Apps & notifications > See all apps > [App name] > Battery > Background restriction. Disable background usage for the apps you don’t need all the time.
  2. Adaptive Battery: If you’re on Android Pie or newer, make sure this is turned on. Go to Settings > Battery > Adaptive Battery. This feature limits battery for apps you don’t use often, learning your patterns over time.
  3. Location Services: GPS eatz up battery like crazy. Go to Settings > Location, and switch it off, or set it to GPS only when necessary. You can also change specific app permissions for location to “While In Use.”
  4. Battery Calibration: There’s some debate over this but recalibrating your battery helps in a pinch. Let your phone run till it dies, then charge it to 100% without interruption. Do this occasionally to keep the battery percentages accurate.
For the power geeks, alright, let’s get techy:
  1. ADB Commands: Connect your phone to a PC, enable Developer Options (Settings > About Phone > Tap Build Number seven times), and go into Developer Options & enable USB Debugging. Open a command prompt, type adb shell settings put global low_power 0 to disable Battery Saver directly.
  2. Custom ROMs: Maybe it’s time to spice things up. Something like LineageOS might have better battery management features. Flashing a new ROM isn’t for everyone, but network-savvy peeps could find this intriguing.
Oh, and about these battery saver apps? Mixed bag IMHO. Greenify is decent for aggressive app hibernation. Still, too much fiddling could cause more issues than it solves. Some phones already have aggressive memory/battery management features, so this can be redundant.
@techchizkid mentioned Quick Settings tiling—true, but they missed one trick: Customize your Quick Settings. Pull the notification bar twice, tap the pencil icon, and drag the Battery Saver icon into your active tiles for even quicker access next time. It streamlines your process without buried menus.
Tidbit for those who mod phones: Magisk modules like Universal GMS Doze can help restrict Google apps/services, typically heavy on the battery.
Finally, speaking about the inconsistency in different Android skins—yes, it’s a pain. Stock Android is different from Samsung’s One UI, Huawei’s EMUI, Xiaomi’s MIUI, etc.
  1. Samsung:
    • Open Settings > Device maintenance > Battery > Power Mode > Optimization.
  2. Huawei:
    • Settings > Battery > Power Saving Mode > Switch it off.
  3. Xiaomi:
    • Security App > Battery > Battery Saver > Tap to turn off.
A lot of times we overlook how some simple habits can revamp our battery life. Like, turn off auto-sync, set brightness to auto or manual, or put your phone in Do Not Disturb mode to limit notifications during specific hours.
In the end, the biggest favor you can do for your phone’s battery life is through balanced usage. Don’t let Battery Saver hold you hostage, but be mindful of those power-hungry apps.
Remember, these steps might vary slightly based on your specific device and Android version. Drop your model details if you need exact paths! Cuz, well, Android always keeps you guessing. :joy:
Recap: you covered app limits, Adaptive Battery, GPS, calibration, ADB, ROMs, Quick Settings, OEM paths, Magisk.
Simpler fix, use Settings search.
  1. Open Settings, tap search.
  2. Type Battery Saver or Power saving.
  3. Open result, tap Turn off.
  4. Set Turn on automatically to Never or 15 percent.
  5. Reopen one key app, test notifcations.
Tip, plug in to disable Battery Saver instantly, then change the toggle.
This works on Pixel, Samsung, Xiaomi. Search skips buried menus and thier names.
